I am wondering, I am using Leadtek Win2000XP as my video input source, I have been capturing into AVI using MJpeg set at 20 for quality, however today I decided to try some of the settings in WinFast PVR software that came with the card. When I capture to a setting called DVD NTSC I get a really good quality video, since I capture into RAID 0 on a 80 GB drive I have plenty of room. However when I capture into that DVD which I am guessing is an MPEG2 I can not figure out how to convert it over into DIVX, when I try to open the file in VirtualDub I am not able to, it will not open it, TMPGenc opens the file fine & it converts it over into VCD for me but I want to convert that movie into DIVX.
Any ideas?
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
Since you got TMPGEnc to open your movie you are halfway home. Once you load your movie, select File-->Output to file-->AVI file. Select the proper DivX format, name the file and save.
Hello.
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 11:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 19:59 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 20:22 -
Avi Or Mpeg to Xivd/Divx
By Castor troy in forum Video ConversionReplies: 2Last Post: 27th May 2007, 10:24
