Hi guys. I have tried for the first itme to use DVD2SVCD and I got a problem. It only ripped a dvd to two 2cds which is good; However, when i burn the second cd image. It is 81 minutes long! and it doesnt fit on one CD!!! Guys please help me out here what should I do?
Change the size of the CDR in the Bitrate tab. Change it to 797mb when you are using cd-r 80 min.
This should solve your problem.
Movman :P -
Actually the files needed to run a SVCD are ~6MB so I'd go with 790 to be on the safe side. But same end result
BTW - it's not the runtime but the bitrate/filesize that matters. You mean the final MPEG was 810MB or something right? -
I set the Bitrate tab to 800mb CD's, and my file size will always be 805mg when finished. I've burned them all this way with no problem, even on an old Yamaha 4/2/6 burner. I burn them using VCDEasy.
Well the bin file can (and often is) slightly bigger than the final size of the burnt disc. Again, SVCDs need 6MB of files/folders so I if you can't overburn then put in 790 to be on the safe side.
MPC-HC upgrade a mistake?
By Monarch1st in forum Software PlayingReplies: 10Last Post: 26th Feb 2012, 14:24 -
please help me, format my camcorder hdr sr-12 by a mistake
By oof7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 9th Feb 2012, 12:11 -
mistake after burning
By gastzugang in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Sep 2007, 14:43 -
Mistake to buy a standard definition TV?
By LT9000 in forum Newbie / General discussionsReplies: 39Last Post: 28th Aug 2007, 09:39
