I'm curious about what the easiest way (well, simplist) would be to rip a dvd to vcd, but with the audio being 48k. Reason for those curious is that this allows you to force the result to be reburned on dvdr without having to do the re-encoding that is talked about from 44.1->48
Directions in dvd2svcd (the program) would be prefered, but if it meens changing to something else, well, thats quite alright for this project.
Thank you.
Saitoh
If you want a lower resolution similar to VCD with 48k audio I suggest MPEG2 DVD half D1 resolution 352x480. With 48 khz audio this resolution video is accepted by most all DVD authoring programs so you don't have to force video programs to burn the low res MPEG1 VCD.
Panasonic DMR-ES45VS, keep those discs a burnin'
48K or 33K audio setting
By devdev in forum Capturing and VCRReplies: 3Last Post: 3rd Sep 2010, 06:32 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 11:46
