ive encoded using TMPG two nights in a row, each time producing horrendously jerky video. Im trying to go down in filesize obviously (movie is 16:9, 23.97 fps). Can someone post ALL of their TMPG settings that would work for this movie to prevent the proper video?
try this tutorial on this site: http://www.digital-forums.com/dvd2dvdr/part3.htm ........the only thing you need to check is the field order..some movies are yop field and some are bottom field this will give you that jerky movie if the field order is incorrect....
just my .02 cent -
sounds like either a field order problem or you didn't dvd2avi with the proper frame type set (progressive).
-d -
ok, after i encode te m2v, i preview it in win dvd and it plays very quickly. Even the time lapse will jump from like :01 to :04 or so. Should i re do the DVD2AVI project?
How to quickly edit Blu-ray? Something like DVD Shrink or Nero Recode?
By peanutty in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Nov 2011, 17:43 -
How to check vob files quickly for entirety
By roberta in forum Authoring (DVD)Replies: 1Last Post: 16th Apr 2010, 16:51 -
How can i quickly edit a wmv?
By Stemondo in forum EditingReplies: 2Last Post: 15th Apr 2009, 20:41 -
How to make DVD Covers quickly with Nero 8
By vain in forum Newbie / General discussionsReplies: 2Last Post: 5th Apr 2009, 21:06 -
How do I quickly identify if my DVD movie backups have bad layer breaks?
By doughless888 in forum DVD RippingReplies: 2Last Post: 9th Jul 2007, 00:13
