I have done many, many DVD burns without a hitch. When I recently upgraded to 5.5.5.100 I have had problems. My Sony NS715 plas the discs fine but my Apex AD-1500 starts loading and then displays 'stop' on the display and on-screen says 'error with disc'.
My normal method has been to select UDF/ISO, uncheck everything except 'ISO level 1' and 'ISO 9660' and burn it. However this has resulted in the above problems with Nero. I have also tried the 'DVD Video' setting with similar results.
I have gone back to earlier versions (5.5.5.82) and they work fine.
Anyone have similar problems?
yes, i have the same problem, same APEX too. I want to be able to play my DVD+r on my APEX and PS2 but i have had no luck. This is my problem... http://www.vcdhelp.com/forum/viewtopic.php?t=139838 I made a forum question pertaining to it. were you able to play on both DVD players with the ISO/UDF mode in your previous versions of NERO? What UDF format did you use?
Problems converting recent mkv's to ps3 format!??
By josetjr in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 06:15 -
Playback of MP4 file on 2 different Macs/Quicktime versions look different
By kmxe in forum Newbie / General discussionsReplies: 2Last Post: 21st May 2010, 10:37 -
Super C Problems - Recent Version
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 18th Jun 2009, 19:04 -
CD Copy with Nero Fails after a few burns
By kadzbiz in forum MediaReplies: 7Last Post: 5th Feb 2008, 19:46 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19
