  1. i burned my movie i downloaded and when i play it on my dvd player the sound is slower than the movie.........
    WHAT AM I DOING WRONG????
    <font size=-1>[ This Message was edited by: neme1 on 2001-09-02 22:40:58 ]</font>
    Feb 2001
    Berlin, Germany
    Before asking "what am I doing wrong", you should say, what you did. At least, if you expect a reply....
  3. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    i burned my avi.movie file to a cd-r using nero and when i play it the audio is slower than the movie
  4. You need to give a little bit more detail than that...
    Was it a DivX?
    What were it's specs originally?
    Has your DVD player ever played VCDs you've created before?
    etc.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. Banned
    Jun 2001
    UK
    Hi neme1,
    When you download a movie play it on your PC first to make sure it is OK. Then when you convert it to an VCD mpeg, play a little of it again before you burn the disk.
    Any problems can be detected then before making a disk. Maybe the original movie was out of sync, or maybe it became out of sync when you converted it to a VCD.mpg
    See if you can detect when the problem started, you don't need to convert the whole of the move, just try a few min's and stop and test the output.
    Use TEMPGEnc to convert the AVI, maybe its Nero that is causing your problem.
    <font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-09-03 05:44:14 ]</font>
