Used Smartripper to rip only the movie (no extras) to two different directories (to split the movie), used IfoEdit to create new IFO's in each directory, chose ""VOB Extras" in IFOedit to correct IFO's, and chose "Get VTS Sectors" with boths discs so they can work in my standalone. Everything is great with the first disc but the second "sometimes" will not play. Its as if you have to wait for the standalone to cool off before it will recognize the 2nd disc. Could this be a cheap media issue? I'm using Princo 2X's, Toshiba SDR3750 stanalone, and Toshiba SDR5002 burner.
Live Long, Play Hard, Think BIG!
Which program you use for recording on Toshiba R5002. I have the same burner and had some problems with skipping and freezing of movies on DVD-R media in standalone player. Now I use ImageTool to create image of DVD after authoring and burn image using DVD Decrypter in ISO Mode - Write 1x. Now no problems with the cheapest media.
Interesting...I might have to try that. I use RecordNowMax and have been pretty successful with it, except for this glitch. Thanks for the info. I will give that method a try!
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 14:30 -
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 16:27 -
"data disk" rather than as an "audio disk"?
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 09:10 -
Final Cut sometimes creates a 2nd file with a "-v" suffix when ca
By jeromedroz in forum MacReplies: 0Last Post: 2nd Jul 2007, 08:41
