Hi guys,
Im trying to change studio 8s capture codec as I belive the codec it uses to capture is the microsoft dv codec, this has a data rate of approx 3500kbs, I have the mainconcept dv codec installed on my machine and would like to use this to capture with as it apparently encodes at approx 5000 kbps, is this true and is this possible to choose another type of DV codec for capture ???
Any other help information on my issue would be much appriciated
thanks
wez![]()
Results 1 to 1 of 1
How do you change the wmv profiles in Pinnacle Studio Plus 12?
By yoda313 in forum Video ConversionReplies: 2Last Post: 27th Feb 2009, 19:09 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Pinnacle studio 11 - max bitrate options always change
By Shikkyn in forum Capturing and VCRReplies: 3Last Post: 20th Apr 2008, 19:27 -
How to add a codec to Studio 9
By Smallan in forum Video ConversionReplies: 4Last Post: 24th May 2007, 02:00 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
