hi
i have lowered the bitrate, to cut down the size, but it aint being smaller,
i have tried, CBR=1150 and CBR=800, but get the same size, anyone have the same prob, or had, or know the answer,, so plz, write back,
thanx
Be sure to select video cd(non standard) under the settings->system tab.
Be sure that you do not use tmpgenc 2.59, it had a bug that caused this problem. Update to tmpgenc 2.510 or use an older version.
Reencoding VC-1 WMV at lower bitrate
By casimps1 in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 23:34 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 01:43 -
reencode x264 to lower bitrate
By reb0rn in forum Video ConversionReplies: 2Last Post: 12th Jul 2007, 01:54 -
Bitrate always comes out lower?
By MrMors in forum Video ConversionReplies: 6Last Post: 1st Jun 2007, 08:37
