I am a newbie in this video thing and i have a problem with the right codec to choose. i have divx5 and xvid codec installed on my system. The problem is a movie i downloaded plays without audio when i open it. The picture is clear and perfect but no audio.
Then i install Nimo codec pack build 8. The audio comes but the picture is terrible with green background.
Can anyone please help on which codec is usefull for my system. I run win xp if it matters. Please!!
I think your movie is a xvid movie with AC3 sound and when you are installing Nimo Pack,you will get the AC3 codec but there is some conflicts with some shit in Nimo Pack.
Just do like this and it will work:
Uninstalled all DivX codecs and xvid codecs,(Nimo Pack etc.)
You can then install xvid codecs from here:
http://www.divx-digest.com/software/xvid.html
Then install all DivX codecs separat (Not from Nimo).
http://www.divx-digest.com/software/divxcodec.html
After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
Install Nimo from here:
http://www.divx-digest.com/software/nimo_pack.html
Now all should work fine!
By the way,AC3 comes with the Nimo Pack and I installed this with
Nimo Pack Build 8,not the new Build 9 -
Originally Posted by Manuxtreme
Only install the codecs you need separately
Test your system to see what you will need
http://www.vcdhelp.com/forum/userguides/135217.php
Best
DivX 5.02 Pro
DivXMPEG4 Hi-Res Video Codec - 3.11alpha release
M$ MPEG 4, V1 V2 V3 (Hacked)
XviD-04102002 (Uninstall after Use)
Moonlight Odio Dekoda, Universal AC-3/MPEG Audio (Layer 1/2/3) Decoder
Fraunhofer Mp3 Pro
Ligos Technology LSX-MPEG Suite v2.0 (Mpeg 2 filters) use with TMPGEnc
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
Converting MOV to FLV - codec problems
By communique in forum ffmpegX general discussionReplies: 5Last Post: 13th Jun 2008, 14:58 -
Codec problems via website only ?
By yukon33 in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 14:19 -
Codec Problems
By Armadillo in forum Video ConversionReplies: 7Last Post: 12th Dec 2007, 12:42 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 08:56
