that was taken from kvcd.net but i have some questions about it.Hello all, I was stoked to hear about an increase in quality with a new template but when I tried it, I only got half a screen off to the left. It had been shifted over. I began reading and noticed that other users were having the same problems. I have found a solution. In FitCD, instead of selecting 3/4 DVD Small, Select 3/4 DVD Full. Then, in TMPGEnc, set the resolution in the KVCDx3 template to 544x480. This gives a us a horizontal value that is a multiple of 32, conforming to the standards of some picky DVD players.
By the way, I am using a GE 1101P DVD player (to correct the chart, it does work). The templates do not work in MPEG-1 on my player but changing to MPEG-2 and selecting 3:2 pulldown solves the problem.
A-Star
1.) Do I have to use FitCD to get KVCDx3 to work on GE 1101? (Ive never used it before at all)
2.)do i change the resolution from 352x240 all the way to 544x480?
3.)how do you add audio to kvcds?
thanks and peaceout
Results 1 to 1 of 1
Visit my webpage at:
http://leech.at/e-z-e
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
