I have 2 mpeg files(downsampled 2 disc DVD), and id like to join them to make 1 movie.
How do you do it in FFmpegX?
It says "Mpeg Join" but where do u put the mpeg files?
Thanx
Q
"Good Luck 007"
In Memory of Desmond Llewelyn -
Select the two files to be joined in the two small file-select fields in the "Tools" view.
It doesnt work.
It says one of them is at 320 bps and the other 192 bps?
Then it quits.
What should i do?
Q"Good Luck 007"
How can I join MPEG-2 files?
By sofakng in forum EditingReplies: 6Last Post: 30th Jul 2010, 10:20 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 01:18 -
can't join simillar mpeg-1 files without re-encoding
By sohaibrazzaq in forum EditingReplies: 3Last Post: 26th Jan 2008, 08:09 -
exporting as MPEG-TS in ffmpegx
By remp in forum MacReplies: 4Last Post: 22nd Jan 2008, 20:30 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 22:36
