Hi there, I'm trying to rip FROM a VCD and convert the DAT files back to regular MPEGs.
VCDGear seems to do this. However, when trying to make a new VCD with the files, Nero says the files aren't in VCD format and asks to convert them.
Shouldn't they already be VCD compatible since I ripped them from a VCD in the first place?! I'm wondering if VCDGear isn't ripping them correctly. They burn to VCD fine after Nero reconverts them, but I know I'm losing quality if Nero is having to tamper with the files.
Anyone know if there is a setting in VCDGear I could fool around with? There is a checkbox in VCDGear to fix MPEG ripping errors but I still get the same results....
VCDGear may additionally be changing the muxing/pack size so that it becomes a "standard" MPEG (i.e., MPEG systems) as opposed to the specific muxing required for VCDs. The emphasis is on "may" since I haven't used VCDGear for quite a while.
You can do the same (convert DAT back to MPEG) with CDXA2MPEG and you can use GNU VCDImager Tools GUI as a GUI: http://www.michaeltam.com/vcdimager_tools_gui.html
If you want to extract EVERYTHING from an existing VCD (all the media files plus an XML descriptor of the VCD so that you and add/delete/edit and existing VCD) then I suggest that you extract a CUE/BIN image of the VCD onto your HDD (e.g., with CDRWin) and then use VCDXRIP on the BIN file (again, you can use GNU VCDImager Tools GUI as a GUI).
Regards.Michael Tam
w: Morsels of Evidence
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Aug 2010, 23:01 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 22:40 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
VCDGear problems
By tricktum in forum Video ConversionReplies: 2Last Post: 26th Jul 2007, 17:03
