  1. im trying to extract a wav file from an AVI file in tmpgenc. at some point in the middle of the processing, it stops and displays an error: error in audio compression.
    how can i solve this problem? are there any other programs that could extract wav from an AVI? or is it possible to fix the AVI so i can extract the wav file successfully in tmpgenc? pls advise. thanks!
    Apr 2002
    The State of Frustration
    Try using Gold Wave (see Tools section). Just load the AVI, and save it as a wave file.
    Hello.
  3. Originally Posted by Tommyknocker
    when i try to open it using Goldwave, the program hangs. pls advise.
    Apr 2002
    Looks like you may have to scan your video for bad frames. Try King John's guide. Click here.
    Hello.
