I don't know if anybody else has had this problem, but DVDSP seems to be picky about m2v streams. Infact it won't let me import any that have been encoded in anything else except the QT encoder that comes with it. I've tried all sorts of encoders, even TMPeg on my PC, but the resulting m2v file appears greyed out in the finder when I go to import them into DVDSP. It doesn't have any problem with ac3 files which weren't created in APack. I was thinking maybe there was something wrong wth the headers in the m2v file or something. Anyone know a way to "fix" these broken m2v's? I don't really want to reencode them all again![]()
Yes, the solution you are looking for is this: More Missing Tools, by RNC. Here is the link: http://homepage.mac.com/rnc/. Use the 'BITS (timecode)' tool on your m2v stream, and if it's gonna work with DVDSP, it'll work after this. A few rare ones will still not work, and you need to use Sizzle or something to master a basic DVD.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
well you could also try draggin the files in question into the assets window instead of importing through the menu, sometimes it will accept video files that way that it wont let u accept through importing in the menu.. a LOT of people dont realize this
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
OMFG!!! That's awesome, thanks for pointing that out! Stupid Apple for letting bugs like this persist so long. Import flexibility is really something they have to work on.
DVDSP output multiple copies?
By MikieV in forum MacReplies: 10Last Post: 8th Dec 2010, 12:10 -
DVDSP Disc only plays on MAC and not my DVD player
By jandajones in forum MacReplies: 3Last Post: 1st Oct 2010, 03:30 -
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 10:23 -
DVDSP Authored DVD - Cleaning the Code for replication?
By Adam Bolt in forum MacReplies: 2Last Post: 20th Jun 2007, 03:45 -
Motion&DVDSP-Square/Rectangular Pixels
By stretchweider in forum MacReplies: 4Last Post: 5th May 2007, 18:41
