I multiplexed the video rendered with cce and the audio rendered with TMPGenc. I did the multiplexing with TMPGenc. When I author it in Moviefactory 2, it re-renders it. It does not re-render it when the video and audio are rendered from cce and multiplexed in TMPGenc. Any suggestions. Thanks.
Have you tried selecting the DO not convert compliant mpeg files under project settings
Michael
Learn to create DVDs the Ezway
DVD Related Question Post them at
www.EzDVDAdvisor.com
DVD Developers Community -
Yes. It does not re-render MPEGs created with CCE. It also does not re-render MPEGs created with TMPGenc. However, I was not happy with an MPEG done in CCE (the audio was not good), so I rendered the audio in TMPGenc and the Video in CCE and multiplexed in TMPGenc. When I tried to author in Moviefactory2, it tells me it has "some rendering" and then it begins to re-render. What do you think? Thanks.
same problem here. I re-encode with TMPGenc. and get the mpeg imported, moviefactory2 always re re-encodes it and makes it way to big to fit DVDr!!!
Tried Moviefactory for the first time last night: I also had CCE video, but I used TooLame for the audio, and then multiplexed into mpeg by using BBMpeg. The Moviefactory took it all right and authored it into vobs.
Sony Vegas Pro mpeg rendering size larger than movie studio
By bbbbbbb45 in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 12:31 -
Smart Rendering and MPEG 2 HD?
By miepel in forum EditingReplies: 16Last Post: 20th Jan 2011, 00:27 -
Rendering MPEG 2 in SONY VEGAS PRO 9
By sfalcon in forum AudioReplies: 1Last Post: 21st Feb 2010, 16:07 -
How do I backup MPEG-4 files on DVD without rendering?
By sentence in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2010, 18:33 -
quickly fix reversed field order w/o re-rendering MPEG-2?
By miamicanes in forum Video ConversionReplies: 2Last Post: 14th Sep 2007, 21:19
