Hi,
I am a noob in hardware encoding as ive been doing much MPEG encoding using software. I dont have the beastiest computer in the world and was wondering would a hardware MPEG encoder really be worth it? Can anyone give me any examples of how much time it would be reduced by, say a 700mb MPEG file?
John
You should expect a hardware encoder to encode real time or faster. It has a built in processor/chip that is built for/dedicated to MPEG-2 encoding.
E.g. a DV camera has an built in DV-encoder that records real-time to DV format on the tape. The quality ranges from poorer than than the software encoders to better than the software encoders. -
Additional Question: can I do this with a HW mpeg encoder:
Capture and edit in DV quality and then convert thru the HW to mpeg-2 (DVD quality)? Does such HW really exist or must I export my DV to DV tape and then import thru mpeg encoder back? -
Most HW mpeg encoders that can pick up any file and encode it real-time are hideously expensive - the "affordable" models - i.e. under $3000 are capture cards
Newbie Hardware requirements
By multistream in forum Newbie / General discussionsReplies: 0Last Post: 23rd Nov 2011, 10:39 -
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
what is the difference between soft, neutral, and sharp?
By noobiestudent in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2011, 17:22 -
What is the difference between a soft box and umbrella?
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2008, 02:29 -
What soft can mux/demux Vegas rendered mpg's?
By Srivas in forum EditingReplies: 8Last Post: 3rd Dec 2007, 05:21
