  1. Hi,
    I'm using CCE 2.50 with DVD2SVCD to convert some .AVI file to SVCD. I have a problem with one of my .AVI files: after some processing, CCE stops with the following error:
    cce encoding failed: Error: Video check-sum is different from thet of previous pass.
    Source video data or time code may be different
    Please check video tape or the information file
    --- information ---
    Current: check sum = 00714bcf
    Previous: check sum = 007147f9
    and theb I can only chose "OK" and the whole process stops...
    Any idea????
    Thanks,
    Toni
  2. Member adam's Avatar
    Sep 2000
    This is covered in the DVD2SVCD FAQ. You need to install the patch that disables the checksum checks.
    http://www.bath.ac.uk/~susajb/Cinema_Craft_Encoder_2_50_SP_CRC_Patch.zip
  3. Thanks a lot Adam. I should have checked that FAQ first... Anyway, thanks again
    Toni
