  1. Does anyone know if it is possible to play a miniDV tape on a PC using only the firewire connection - Meaning could I just hook up the cam and play the digital movie directly from the tape to watch on my monitor somehow?
  2. You can use the "Amcap" freeware program for this:
    http://noeld.com/dlvconf.htm
    You can also try this "TV Viewer" shareware program:
    http://www.geocities.com/matroxfiles/tvviewer.html
