I got a couple of good quality avi movies but on each one of them there is annoying copyright message that appears every few second. The message is on the movie not on the bottom(black) part of the screen. Clipping the movie won't work because I have to clip a lot. Also removing the frames that have the message makes the movie out of sync, and it doesn't look good because I have to remove I lot of frames.
Do you have any suggestions about how to remove then.
I agree with BJ_M but also will say this
most filters like for virtualdub work on static images like logos. Moving images will leave a blurry streak where the message scrolls, unsatisfactory to most so you'll probably not find anyone willing to put the work into it.Panasonic DMR-ES45VS, keep those discs a burnin' -
For your considerationOriginally Posted by vtoskov
There have been methods posted for removing subs and scrollers, but what ever method is used, they wont be able to "Cut out" the section, only replace it with a blur of adjacent pixels. To me they are more annoying than the message.
Removing chapters from BDMV format
By thepreacher in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Feb 2012, 11:16 -
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 11:05 -
Sample MPEG-2 video with SCTE-35 cue messages
By bharatbiswal in forum DVB / IPTVReplies: 1Last Post: 17th Sep 2008, 13:50 -
How to create a forum that allow to record webcam and post video messages?
By deafeagle in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 14:03 -
Ok, captured my video as AVI format
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 00:37
