I downloaded a couple of DTS and DD VOB files. The intro's used in the movies. I want to be able to dump them in a DVD-R and play them on my Top Set DVD player. What do I need to do to them to get them to play??? Do I use nero and just burn them. Will nero create the .ifo and .bup files???
You must author them first. You can use ifoedit(supports dd and dts) and burn with nero.
http://www.vcdhelp.com/forum/userguides/120021.php -
I follow the link tried it worked great. except that when I read to burn with Nero. It give me message "DVD-Video files reallocation failed. The resulting DVD-video might be unplayable. I hit ok -> next "there has been a possible read error during operation which may result in a defective write. And it works great in the PC..but my DVD player won't play it. Any help wil be appreciated....thanks guys..
I also download the intros, mainly 5.1 audio not yet DTS,
i did the following:
striped the mpeg2 from the vob and the AC3 stream
mux them together with TMPGEnc
And Author with Ulead DVDws
its easy and good
now in ulead dws you can dump the mpeg2 file for the first playing
and after authoring it will create for you all the vobs ifo's and the rest.
now about DTS, baisicly its the same but i need to know how to mux mpeg2 with DTS stream file. -
So you break the sound and video apart, put it back together, and that works... I'll give it a try, but I'm mystified.
Free program to join vob files with dts audio
By shans in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2013, 06:50 -
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
VOB files - Video _ TS folder wont record dts codec on toast 7
By BattyRoy in forum MacReplies: 8Last Post: 10th Apr 2008, 00:30 -
How to cut vob file by keeping DTS track
By sureshforum in forum EditingReplies: 2Last Post: 1st Feb 2008, 09:13 -
VOB DTS file to VOB AC3
By shanthaprasad in forum AudioReplies: 4Last Post: 25th Sep 2007, 13:34
