Hello,
One more newbie here...
I have few DiVx cds and I would like to convert them to VCD. Video files have an extension .VID and I can play it with Windows Media Player, but I cannot convert it to anything. TMPG and other programs keep saying: ”Format is not supported”... Any help would be appreciated.
BTW, using GSpot I got following information about my file:
Video Format: Codec COL1
Aspect: 480 x 328 (1.463 : 1)
Bitrate 471 kb/s
Framerate 24.999 FPS
Thanks in advance.
Myself, I'm not sure. But, something tells me KingJohn would be able to answer this one. Send a Private Message to KingJohn, and he will probably be able to help, he knows all!!! Good Luck!!!
Better late than never I suppose. You have encountered yet another old hacked version of the MS-MPEG4 called Cool1.
Some smartass has hexedited the FourCC code (which is how Windows identifies the format of a video within an AVI file) from MP43 to COL1 (there are also entries for col0, COL0 and col1). This is similar to the "Angelpotion" codec that you might see floating around on the net and also why Media Player can play it but TMPGENC chokes.
To fix it just use AVI FourCC Code Changer to change the codec to DIV3 (if you have DivX installed) or MP43 (if you would rather use the MS version).
You may as well remove the phony codec as well by starting Device Manager going into "Sound, video and game controllers" then get the properties up for "Video Codecs" there should be an entry for coolvideo/angelpotion or something similar just higlight it and click remove.
P.S. I think you'll find a VID file is just an AVI file with the extension changed.
Convert webcam images to time-lapse vid, thenupload to YouTube...NEED HELP!
By EricFW in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2012, 05:34 -
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09 -
ADVICE NEEDED... as of today, what is BEST vid format to convert DVDs???
By carapalida in forum Video ConversionReplies: 4Last Post: 7th Oct 2007, 16:39
