I have a SVCD I think, it has mpeg2 file and Toast recognizes it as "CD-ROM XA" I want to make a copy of the disc. I tried making a disc image first, then burn. I tried direct copy (disc to disc) and it doesn't work. It's definitely not a VCD, the quality is much better. Inside the disc are 3 folders: SVCD, MPEG2 and EXT
Anyone have a solution? I'm on OS 9.2 with Toast Titanium 5.2. Please HELP!!![]()
AnonymousGuest
I can't believe no one has replied to u yet.
If you have an svcd on disc, all u need to do is use the "copy" mode.
Thats it!
Enjoy -
If you are having difficulty w/ direct disc-to-disc, try "Device Copy" (its in the dropdown for Other) and select your disc, then save as a disc Image.
Then, burn the disc image.
Unless the SVCD has some unusual copy protection, it should work smoothly.
HTH,
