An ISO/IEC (International Organization for Standardization/ International Electrotechnical Commission) standard for medium quality and medium bitrate video and audio compression. It allows video to be compressed by the ratios in the range of 50:1 to 100:1, depending on image sequence type and desired quality. The encoded data rate is targeted at 1.5Mb/s - this was a reasonable transfer rate of a double-speed CD-ROM player (including audio and video). VHS-quality playback is expected from this level of compression. The Motion Picture Expert Group (MPEG) also established the MPEG-2 standard for high-quality video playback at a higher data rates. MPEG-1 is used in encoding video for VCD. MPEG FAQ
Results 1 to 1 of 1
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
