I recently updated the firmware for my pioneer dvr 104 to 1.32. But every time I start my pc now it says new hardware found, it prompts me to install a driver but I haven't got one.... Where should I look?
very dangerous doing that, tried system restore,
probably wont help, can u downgrade ur flash? -
just go ok & if its win2k or winxp have your cd handy & it will look through the disks till it finds a driver, although I never had this problem
CD-Roms, DVD-Roms and CD/DVD writers/re-writers etc don't have drivers for Win9x and above (only DOS needs a driver), they use the std builtin MS driver.
I think your firmware upgrade went a little wrong
Go here and check for any info http://forum.firmware-flash.com it's a geat site for firmware and problems regarding it.
I hope this helps)
I'll check out the link to see what i can find, but my DVD-R drive is still working okay????
Better use 1.31 2x4all if you want burn 2x and 1x at your choice. Infos and links via the side named before.
HELP PLEEEEEEZE! Pioneer DVR 111L Writer, Need Driver
By golfnut in forum DVD & Blu-ray WritersReplies: 6Last Post: 18th Feb 2010, 21:09 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
Pioneer dvd-rw dvr-112D Driver Update
By scustalow in forum DVD RippingReplies: 1Last Post: 27th Jul 2007, 13:16
