I got a 703 mb big DivX file, and i want to cut of 3-4 mb (some seconds) so it can fit a normal 700mb cd. And therefore I followed the guide (from www.Doom9,net) to cutting in VirtualDub (using 1.4.7). I can make the new file and all that. But when i try to play the movie in WindowsMP/MicroDVD it's laggy... It's not REAL freezes because the movie countinues after a 1/2-1 second, but it's laggy.. also after some time (20-30min) the sound disapear ?
I have also tried to use Audio Interleaving.. but same result
I got a
800 Mhz Duron, with 256 MB SD-Ram
The originary movie works fine, but when i cut it it go crazy
Other movies runs fine! - No Problemo!
It just lovees up when editing video or audio. Don't know why.
Whats wrong, how do i get it to stop the lag, and how do i make the sound continue!
Thx in advance
Simon Skov Boisen
Denmark
<font size=-1>[ This Message was edited by: SkovBoisen on 2001-09-02 13:23:22 ]</font>
i just read an article that you can make 703 mb fit in a 700 mb cdr. when you encode it, use mpeg 2 and not mpeg 1 and use 352x240 resolution. try it and let me know. i plan to try it myself.got a question for you, how do you cut or delete some frames using virtual dub?
Erh
check the guide on http://www.doom9.org
and.. i'm not ecoding the file.. just editing!
so plz someone help me! -
You can burn 703 mb on almost every 700 mb cd. Don't edit it, just burn it.
And gadget, what are you doing with the resolution 320x240? How do you watch that?
P.
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 09:32 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 01:35 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 11:45
