When using the VDub to resize a avi capture from 640x480 to a CVD or SVCD format which option in the resize filter should I use (nearest neighbor or bilinear or bicubic or precise bilinear or precise bicubic or...)
obviously you should use the one that looks best to you
however most people consider Bi-Cubic or precise Bi-Cubic
however there are some who say the bi-linear is best for scaling down
Megui Resize Filter
By xxxThiefxxx in forum Video ConversionReplies: 4Last Post: 18th Apr 2012, 23:00 -
resize filter in virtualdub for upsizing videos
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2011, 06:26 -
Resize filter in VirtualDubMod
By CSULB71 in forum Video ConversionReplies: 5Last Post: 28th Dec 2008, 11:48 -
How to use the Resize filter with WinAvi?
By GangstaRap in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 05:28 -
Which one directshow filter to resize the image ?
By jazzzy in forum Software PlayingReplies: 1Last Post: 20th Feb 2008, 09:55
