  1. I have 2 videos that i would like to convert and 1 of them is .WMV and the other is .ASF but neither of them will work in Tmpeg encoder it just gives me an error and exits. Nothing works and there doesn't seem any program that will work to do the job. Any help would be gladly accepted.
  2. open in moviemaker then save as a dv-avi? or a file type tmpgenc will accept?
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    had the same problem.
    check in the tools section here, look for Stoik Video Convertor - it's a freeware that will convert .wmv to .avi, (for me on a AMD 950 / 256Mb ram it does almost realtime - 28 or 29 fps).
    From the .avi, you can convert to mpg for vcd.
    good luck.
    - housepig
  4. Banned
    Jun 2001
    UK
    Try this
    TMPGEnc
    Option > environmental setting > VFAPI plug-in > DirectShow multi medial file reader
    Right click and select higher priority, do that several times until its at the top with a value of 4, or just below any Mpeg 2 filter.
  5. I tried VFAPI plug-in and i got the exact same error that exits the program and leaves me without any progress. I also tried the Stoik video encoder and it doesn't work for me..... It just blanks out and dies..... There has to be program out there preferably a free one....
  6. Banned
    Jun 2001
    UK
    Search my posts for WMV/ASF with graphedit
