what does this mean?? it has nothing to do with my cursor and it only happened wen i'm in the source code for TMGEnc and wen i stop the encoding process. which bring me to another point during the encoding process the first six minutes r smooth and than the encoding screen goes black.
What? Do you mean you're debugging the source code (not likely since it's not open source)? Provide a little more detail on what you're doing when you stop the encoding.Originally Posted by Rizzo2000
Did you check for bad frames ?Originally Posted by Rizzo2000
http://www.vcdhelp.com/forum/userguides/135552.php
Pointer disappearing
By Jeikobu in forum MacReplies: 5Last Post: 19th Oct 2010, 07:32 -
AG-1970 operation question
By jcolegrove in forum RestorationReplies: 3Last Post: 12th Apr 2010, 12:35 -
Invalid Pointer error #80004003 PowerDVD - solved
By montrealer in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2009, 09:49 -
weird null pointer exception when intialization Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:25 -
vista DVD maker invalid pointer
By sue1951 in forum Authoring (DVD)Replies: 1Last Post: 19th Jul 2007, 11:04
