    Jan 2003
    australia
    changing a avi to vcd format,using all of the programs suggested,following the guide to the letter!-divx fix,virtual dub,tmpgenc, then using vcdeasy to burn with, runs fine on the pc before converting and after converting, and after i burn it and try to play it on my standalone dvd player,the audio runs excellent,but the video seems to freeze a little,thought this was just due to my own crappy dvd player(xlogic) but ran it thru a few different dvd players,same problem,audio fine,but picture seems to freeze for a few seconds,sometimes minutes at a time.HELP!! what am i doing wrong?? HELP!!!!!thanks in advance
  2. Banned
    Jun 2001
    UK
    Use Vdub MP3 for bad frames !!!
    http://www.vcdhelp.com/forum/userguides/135552.php
    Make sure you load a VCD template PAL/NTSC
  3. Anonymous
    Guest
    heyitsme123... still there? hit me back!
  4. Mod Neophyte redwudz's Avatar
    USA
    infected, please don't dig up old threads to post in. Both members are likely long gone and the OP only posted once and that was in 2003.
    Moderator redwudz
