  1. Is there a setting in TMPGEnc that can soften the soundtrack on conversion of a VHS PAL video to Cannopus AVI as it is becomies harsh and sibilant, but the original AVI is fine. This applies to old and newer VHS source, or is there a known problem with Cannopus/TMPGEnc?
    Thanks.
    Cole
    May 2001
    Where does it become sibilent? Before TMPG or only after? If after, use another package (ie, one that specializes in audio processing) instead of TMPG.
  3. It is after. This has only become a recent thing though. Any recomendation?
    Cole
  4. Member p_l's Avatar
    Montreal, Canada
    Try using the SSRC frequency converter. Download and extract it to the TMPGEnc folder, then in TMPGEnc, go to Option/ Environmental Setting / External Tool and under Sample frequency convertor, browse for the location you extracted ssrc.exe to. SSSSolved my ssssibilant ssssound sssituation.
  5. p_l, much appreciated, I will give that a go.
    Thanks.
    Cole
