Picture this:
2 CD SVCD title in bin format.
I extract the MPEGs using VCDToolsX
Then demux them both
Remux as DVD
Disc 1 works great, while disc 2 (and 3 if that is the case) won't mux at all - the program(s) all say the mp2 is unrecognizable. It plays fine in QT etc, so I know the file is OK. Any easy way of forcing a proper header on it so it is acceptable to the mux prog?
Thanks for your help,
/Wizeman a.k.a. El Rocho
"I have not failed. I have only learned what does not work."
-Edison -
The easy way is to use the Decode MP2 function of MoreMissingTools.
But...the guananteed way is open in iTunes > Convert to MP3; open in QT > Export to WAV; your favorite tool back to MP2.
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Captured AVI frames broken/split/badly aligned
By cyclometric in forum Video ConversionReplies: 3Last Post: 25th Sep 2008, 07:50 -
I Need New Burner Recommendations Badly
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Sep 2008, 16:05 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
