Seems to me that I am the ONLY ONE having a major problem here... this is my last try for help, no one seems able to help me.
I record a Movie through my video in card in an uncompressed mpeg-1 file. (about 2 gig per hour). I then use virtualdub to extract the audio. (i already checked to make sure that the bitrate i record in is the same as what i am encoding to)
I then try to encode the movie, and success using seperate audio and video files! (i tried with just the mpeg-1 and i get major audio sync probs), I then look at it on my computer and for about the first 10 minutes, its perfection. After that, the audio slowly gets ahead of the video, as much as half a second or so. Enough that its completely noticeable. So i cant use the audio correction, because its not the same throughout the movie.
Now, i recorded in 29.97 bitrate, would it fix my problem if i encoded in 30 bitrate? so that the video might be able to keep up with the audio? do you have any other suggestions to try? I have tried everything i can think of, and I seem to be the only person having this problem. I AM SO FRUSTERATED!!!! i have spent weeks trying to fix this problem now...
Thanks for your time
Syndrome
Hi Syndrome,
You seem to be somewhat cofused in your termanology.
mpeg-1 IS a compression format. I have not done any capture in this format but from what I have read it is common to have audio synch issues.I record a Movie through my video in card in an uncompressed mpeg-1 file. (about 2 gig per hour).
I do not know what format you are trying to end up with (X/VCD, X/SVCD, or DVD) but since you are refering to mpeg-1 I'll assume VCD. If this is the case I don't see any reason to reencode your original capture (if you are truly using mpeg-1 to capture.I then use virtualdub to extract the audio. (i already checked to make sure that the bitrate i record in is the same as what i am encoding to)
If your original file is perfect for the first 10 minutes and then drifts out of synch, reencoding is not the answer. In fact I do not know the answer.I then try to encode the movie, and success using seperate audio and video files! (i tried with just the mpeg-1 and i get major audio sync probs), I then look at it on my computer and for about the first 10 minutes, its perfection. After that, the audio slowly gets ahead of the video, as much as half a second or so. Enough that its completely noticeable. So i cant use the audio correction, because its not the same throughout the movie.
What you are referring to here is framerate. A bitrate of 29.97 or 30 would be terribly poor qualityNow, i recorded in 29.97 bitrate, would it fix my problem if i encoded in 30 bitrate? so that the video might be able to keep up with the audio? do you have any other suggestions to try?
. I do not believe that adjusting your framerate will fix your synch issues (and could lead to other problems
). I think that additional information is required:
- Are you truly capturing to mpeg-1 (what is the extension on the file mpg, avi???)
- What kind of hardware are you using (capture card, firewire, dazzle, sound card???)
- What format do you want to end up with (divx, VCD, SVCD, XVCD, XSVCD, DVD, etc)
Sorry that I cannot fix your problem, but if you could follow up with a bit more information prehaps I (or one of the real experts out there) can help you out.
-Smells_Like_Feet
I would like to help too.....but "Smells like Feet"is right; try to give the right information; about what you have/ want to do! Also specify about the programms you use.
D.C. 8)
Frusterated with Video 8 to DV with a EV-C100 and ADVC110
By myoung08 in forum Capturing and VCRReplies: 2Last Post: 23rd Jul 2010, 13:10
