A fast, lossless Win32 video codec developed by Ben Rudiak-Gould. "Lossless" means that the output from the decompressor is bit-for-bit identical with the original input to the compressor. "Fast" means a compression throughput of up to 38 megabytes per second on a 416 MHz Celeron. Huffyuv is intended to replace uncompressed YUV as a video capture format. It is fast enough to compress full-resolution CCIR 601 video (720 x 480 x 30fps) in real time as it is captured. Huffyuv also supports lossless compression of RGB data, so it can be used for the output of programs like VirtualDub. Creator's Site
Results 1 to 1 of 1
huffyuv help
By liquidr0x in forum Video ConversionReplies: 31Last Post: 18th Feb 2015, 07:31 -
How do I install Huffyuv (mt)?
By blud in forum Newbie / General discussionsReplies: 8Last Post: 6th Apr 2012, 07:47 -
HuffYUV Question.....
By vipin in forum Video ConversionReplies: 7Last Post: 7th May 2010, 13:36 -
H.264 to HuffYUV
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 4th Apr 2008, 01:25 -
capturing to huffyuv
By nagihcim1 in forum Newbie / General discussionsReplies: 9Last Post: 4th Sep 2007, 21:07
