converted avi/xvid-svcd with dvd2svcd & cce.
everything worked out, only the picture is (slightly, but annoyingly) stretched when i try to watch it on tv. works ok with cyberlink on pc-screen, but i want to watch it on tv, don't I .)
i checked 16:9 borders added, encoded as 4:3 (source avi is 1.818:1 (or 16:9)) as the faqs told to use 16:9 the closer the ratio get's to 2:1.
all the other boxes are checked according to the latest guides.
the problem is that i can't seem to find something like "encode to 16:9 KEEP ASPECT RATIO" like i do in Tmpgenc. because that worked using tmpeg standalone (unfortunately my dvd2svcd always crashed using tmpeg, so i use dvd2svcd&cce ).
so there's only the 4:3 or 16:9 option in the dvd2vcd convertion register. anywhere to keep the RIGHT aspect ratio ?
i don't mind missing parts of the screen (as i don't have a 16:9 tv), but the proportions should be right.
any hints ?
thanks
Results 1 to 1 of 1
2.35:1 AVI plays back stretched on HDTV
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2011, 18:11 -
H.264 conversion/frames missing/skipped
By iGnight in forum Video ConversionReplies: 18Last Post: 29th Jan 2011, 02:23 -
Skipped frames in VOB conversion to DV.
By wasimismail in forum Video ConversionReplies: 1Last Post: 24th Apr 2008, 19:23 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 08:01 -
FLV conversion adds white frames at end of clip
By jörg_w in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2007, 14:12
