Hi,
my cousin just purchase a panasonic dmr-hs2, and was wandering if we could replace the built in 40 gig harddisk with a larger one either 80 or more gig harddisk. will a bigger harddisk run in this system or it is really design for a 40 gig capacity? cause once when he start to record it will be a six hour straight and other 2 hr for 4 or 5 days which leaving him not enough time to process all of these.
thanks in advance for your help.
dvd knight
i dont think you can -- but you could always try ... of course you will have to format it the same
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
