I used DVD decryptor to rip the main movie files only, so by default it neglects to rip 4 other 'needed' files. I am remuxing currently and at last check my files still played with software players. Do I NEED these other files? and if so, what should i do to get them? can i simply rip them from the movie and place them in the same dir as the remuxed files? thanks in advance
Of course you need them ! A standalone player will not know how to play the disc without them...
Chances are you will have to edit them slightly in IFOedit after a rip / re-encode anyway (eg Get VTS Vectors), but yeah, if you've got the original disc then just copy them across.
If you haven't got the original, use IFOedit's "create IFO" function. Select the first VOB file in the sequence and away you go. -
alright, remuxing just finished, going to rip them straight to the dir into which i just put the new remuxed .vob's. hope this works.
Batch/Queue video_ts.ifo to MKV lossless ?
By fional in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jun 2011, 18:03 -
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 08:54 -
How do I create VIDEO_TS IFO from VOB files
By stockton209 in forum DVD RippingReplies: 2Last Post: 8th Jan 2010, 04:07 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 11:39
