Which version of Nero? I'v got 5.5.10.0 and it works great - not a singe coaster yet. Can you upgrade?
Regards,
Rob
Results 211 to 240 of 645
i purchased this program earlier today..
tested: LOTR (widescreen edition)
selected: english audio & subtitles
i must say, i am quite impressed.. this is so amazing.. i dont have to fuss around with many different programs, reading guides and worrying about ******* up one step, out of sync subtitles and all the other bullshit that used to be associated with converting a dvd9 to dvd5..
now as for quality.. i'm sure there is a decrease in quality, but honestly, unless you're an anal quality freak you're not going to notice.. and i did a really long movie, and i didnt notice anything..
when this program supports including menu's & splitting a dvd to 2 discs it will be the only program i will use (as far as transcoding dvd's)..
cce does offer better quality, but its hard to notice.. i DO notice spending HOURS longer to encode the movie and going through tedious steps to do what this program does in 20 minutes..
i say, **** CCE (as far as transcoding dvd's)..
as this program advances it is going to be a HUGE step towards making dvd burners as mainstream cd burners..
some of the best $40 i've spent
go DVD2ONE!! -
aznguy wrote:
I made a post, but no one reply to it... So I'll try here...
Sorry if its a stupid question as I'm new to DVD Authoring!!!
after using DVD2One, is there a method or way to keep the extra and menus???
The menus are easy to add though which will keep things like chapter selection, but the links to any special features will be diabled:
Adding the Original Menu:
I think that the procedure should go as follows but I'm at work and so if anyone spots any mistakes just point them out!
You will need the following software:
DVD Decrypter (or Smart Ripper if you prefer)
DVD2One
IFOUpdate
1) Use your favourite ripper to decrypt the DVD to your hard disk in file mode (this will be the ' Original Folder'), and select all the movie VOBs along with:
VIDEO_TS.IFO
VIDEO_TS.BUP
VIDEO_TS.VOB
and VTS_01_0.VOB (this assumes that the main movie is in VTS_01_1.VOB etc)
2) Use DVD2One on the 'Original Folder' and save the files it creates in a 'New Folder'.
3) Delete the movie VOBs ONLY from the 'Original Folder'
4) Copy the movie VOBs ONLY from the 'New Folder' to the 'Original Folder'
5) Run IFOUpdate. In the first field select the 'VTS_01_0.IFO' file from the 'Original Folder'. In the second field select the DVD2One authored IFO from the 'New Folder'. In the third field give a location for a backup file (use a temp directory).
6) Click 'IFO Update' then 'Correct VTS Sectors'
7) Et Voila! Check it out with WinDVD (or whatever) to see if it works.
I hope that's the complete process, but I am open to corrections!
Also note that this will only work if the menu is small enough to fit in the remaining space on the disk. DVD2One seems to get very close to the maximum size so it may be a tight squeeze. -
IvIark your guide for using the original menu is a good one but it aint gonna work as DVD2one takes all the space of the disc only about 13/14k left not enough for the menu.Someone in an earlier post did hit on the idea of selecting an extra audio or subs that you don't need and let DVD2one do its job then rip out the extra audio/subs with IFOEdit giving u the room to insert a menu.........
SORRY IVIARK DIDN'D READ ALL YOUR POST I C U DID MENTION ADDING EXTRA AUDIO.............
Sorry to sound stupid, but what's the point of having a menu if you can only 'order one thing from it'? i.e. chapter selection. Won't the |< and >| buttons on the remote do the same thing?
Regards,
Rob -
Using an audio track may be a bit much, maybe keeping an extra stream of subtitles and stripping them out will give you enough space. -
rhegedus wrote:
Sorry to sound stupid, but what's the point of having a menu if you can only 'order one thing from it'? i.e. chapter selection. Won't the |< and >| buttons on the remote do the same thing? -
well Im am most impressed with this!!!!!!!!!!!!!!!!!!!!!!
I have used various methods of encoding video, using REMPEG and CCE and on most occasions it has never worked properly for me, usually the fact the movies never would worked in my PS2, in fact thiers a few posts on this forum about how i couldnt make it work.
Anyways I see this as a idiot proof way of making excellent DVD9>DVD5 copys.
I just did LOTR Fellowship of the Ring - Directors Cut, and barring the time it took DVD Decrpter to copy to hard drive(15mins) the encoding bit took just 16mins approx for both discs on my Athlon (+XP2400)
Im sorry I havent read all the previous posts but this is the instructions I was given by a mate.
OPEN dvd-decrypter select the drive the dvd is in, click mode go to file mode that will select the movie file for you.
Go to tools and select settings in general make sure macrovision removal is ticked
on file mode make sure you have a tick in
select main movie files
remove ifo/bup rc protection
remove ifo/bup rce protection
remove ifo/bup puos
now click dvd and sit back and watch it store on your drive
once done open dvd2one
On the first screen, select the source and destination directories
On the second screen, select the title that contains the main feature
On the third screen, select the audio tracks and subtitles you want to include in your copy.
Then click the Start button and processing begins
sit back and wait till its ready
Then burn resulting folder into your favorite DVD bunring software i.e. in VIDEO_TS folder.Verb media and never a problem....
~~Pioneer A07XLB~~
~~Sony DRU510A~~ -
Just enter the new encoded VIDEO_TS as a source to DVD2ONE, and process it again stripping the audio that you don't need. It is faster and foolproof...
Antonio S. -
Hi All...
I just bought that excellent piece of software and it's great!
I tried in a Dave Mathews Band concert (2:15:00) and noticed that dvd2one lowers the bitrate, for example there is a part when it lower it from 4mb to 1.4mb. All you have to do is check "Show Information" in PowerDVD.
I have read people stating that they prefer spending 4 or 5 hours just reencoding using an expensive program over spending 40 minutes on a $40 software...and they complaing about some block they saw...
People, if you are so picky with the quality, just buy the original DVD again and you will have a bit by bit backup! -
quote from author on afterdawn.co.uk as follows from people who asking whether it is a hoax as follows:
Hello,
Thank you for your responses.
Not the entire program is made in assembler only the parts where speed realy mathers
And i can asure you it is NOT a hoax, our software doesn't do a entire re-encoding like CCE does, but uses some advanced techniques to compress the allready encoded movie.
This compression engine is smart, i constantly measures the output size so it will make optimal use of the 4.37 Gb UNLESS the movie with stripped streams is shorten then 4.37 in that case it will just rebuild the structure of the DVD so you can burn it to a DVD-r
Ordering is only possible via our website (http://www.dvd2one.com) we use a secure CreditCard system for safe transactions.
I just would like to mention the obligatory copyright notice. we we will not tolerate piracy or the trading of license-keys.
If we find out you are sharing or spreading your license-key we automaticly void your registration and you're not allowed to download any future upgrades.
If you have any problems or questions about the program feel free to ask me. -
Hi all
Need a Little help just trying DVD2one and i keep getting this
when i try to back a dvd
Encrypted data detected dvd2one can not decrypt protected data
any help would be nice -
[Edit] Too late -
bat21: have you ripped the dvd to your hd first? Use www.DVDDecrypter.com and rip to your hd in file mode.
(No I was too late.)
Originally Posted by mikef07
I just wanted to see how it would handle a film that you'd have to reencode anyhow. XXX is slightly bigger than what would fit on a DVDR so I wantd to see how it would handle it.. -
BAT21 I just posted the simple instructions about 10 posts up, hope that helps.
~~Pioneer A07XLB~~
~~Sony DRU510A~~ -
Here's a question if you were going to copy a movie lets say Undercover Brother. It's short enough that you can get the DTS and DD tracks without reincoding it. Would you expect to get the same video quality if you did this the old fashion way with Decrypter,IFOedit,Chapter Extracter, and DVD Maestro as you would if you simply used to DVD2One? It would probably take about the same amount of time but it's one step. Or would you be better off using the original method
Once this software can do what I *really* need it to do, then maybe it's the solution many of us cappers need, which is to get around long encoding times. I don't rip DVDs, so in that this software is useless to me. What I do is capture video at high Mpeg-2 bitrates and reencode to lower bitrates for my final product. Is there some way that the software can do this or is that still in development? Any way to make the Mpeg-2 file into a fake VOB so it can be reencoded? Encoding times vary, but to do SVCDs, 45 minute file takes 5 hours on my PIII 1GHz! If this software could do a reencode to a lower bitrate in only 1/2 hour (or less) like it does for DVDs, then I would buy it right now...
Thanks for the brief explantion :P
Ok I don't have a DVD burner so will it be worth buying one just to back up DVD movies with this DVD2One software or would it be better to buy a standalone DivX player ?
Originally Posted by dun4cheap -
Just got done ripping Stephen King's Rose Red Disc 1, the DVD is actually 2 original dvd's and I am completely amazed. It fits using DVD2ONE on 1 dvd-r, the 1st original dvd does I mean. It was over 8 gig and it's now 4.37 This is awesome and it looks good enough for me 8)
I just did a movie that was 6 Gig of size (movie only).
I did it using DVD2one in 19,5 minutes and using CCE (DVD2DVD-R) in about 6 hours.
I must say there is a difference in quality... the one encoded with CCE is better! So I will stay with DVD2DVD-R at the moment, but I will keep my eyes on the future versions of DVD2one!
-BK-
Check out my website ... -
Originally Posted by susie
definetly get yourself a pioneer a05 and some good 4x media and use the hell out of this software..
if jesus were a computer, the arrival of this would be his second coming -
Little help here!
I am trying the demo version. Made my 30 minute movie. The vob file plays back OK. When I burn it with Nero 5.5.9.0 in DVD Video mode, the disk just skips in large increments. I always use Nero this way and have never had a problem. Is it Nero or something with the DVD2ONE process?
Thanks again.
Rodger -
Little help here!
Try DVD-UDF instead. Make sure you select "No Multisession" and UDF 1.02 partition. Should work fine. -
I have a DVD burner since 2 weeks only, but have reencoded a lot of SVCD using CCE.
I think this soft is great for people without time, and/or low specs machines, but i can see very clear the macroblocks that this very good programmed piece of soft produces.
For me its like returning to the svcd thing or worse. Maybe worse, becouse in svcd you have a lower resolution and you can compress bether with less bit rate. (less artifacts)
In one film i have converted with DVD2ONE (Aliens), it has lowered the bitrate to only 1.5 mb in some very dark scenes. I can see macroblocks there. Its obvious, and all people with a decent TV set would see it. (and i only have a 4/3 29" Sony, not a widescreen tv).
If you can live with macroblocks thats perfect, but the fact is that you can see they if you look carefully to the screen. (i can!)
I have been happy making svcd last years, and have converted a lot of films using DVD2SVCD, but i have changed to ripp to DVD becouse the increase of quality it offers. If using dvd2one i will obtain almost the same quality image that i have obtained with svcd i chosse to recompress it with DVD2DVDR (CCE). It makes all the conversion process itself, and the output have real great quality.
Dont blame me. I think DVD2ONE is great, but not as great as the slow metod of real recompression with a professional codec like CCE.
Its only Time us Quality.
Pd: (sorry. My english is not very good) -
Originally Posted by destrozeitor
-BK-
http://users.pandora.be/DVD2DVD-R
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
