Read my post about 4 posts up. Same concept
Results 451 to 480 of 645
Originally Posted by Silky31
Thanks!
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
ANy questions let me know. On another note, will some coputer experts answer this question for me. Very short.
http://www.vcdhelp.com/forum/viewtopic.php?t=140883 -
Would you be kind enough to put a (very) brief guide together for those of us wanting to do the same thing?
http://www.vcdhelp.com/forum/viewtopic.php?p=440026&highlight=#440026
Like I said in that original post, it certainly turned out lower quality, but it looked considerably better on my standalone and TV (29" Sony 4:3) than it did on my PC and not as far away from the original as I originally expected. -
Originally Posted by gobama
I sthere any special settings I need to change such as 'multisession' (load last track?), Recording type (TAO) etc?
Thanks,
Originally Posted by shelbyboy
Could you help?
Thanks,
All u all have 2 do is load dvd decryptor, set file splitting to none, Load the big vob file to TMPG audio and video, make sure in environment mux is set and encode, it will take 45 minutes max on 2 hr movie. Author dvd then burn. It will b a perfect copy of your hard bought movie.
Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live! -
I've been having problems getting RecordNow Max 4.5 to burn the AUDIO_TS and VIDEO_TS folders. It'll burn the files but not the files and the folders. My woeful tail is described on pages 9 & 10 in this forum.
I found a note from someone on another site who was having the same problem. The note reads...
"I have taken the folders that wouldn't burn with RecordNow Max and ran ifoedit running the "get VTS Sector" part again. Now everything burns fine and is playable by my standalone player."
I downloaded ifoedit and have no idea how to run"get vts sector" on the folders. Does anyone have ifoedit and understand what this guy did to the folders? I'd sure appreciate a walk through so I can get this "burning" issue resolved.
Many thanks... -
I see that no 1 has responded to my post as yet! Any way all this hype about dvd2one is all good, but like I said u can do the same thing in TMPG if u follow my steps outlined in earlier posting. That simple, same amount of dvd quality in 45 min to 2 hours, including burning.
Originally Posted by Jah_Rankin
Until I get this RNM burning issue resolved, I won't be able to compare apples to oranges on my standalone DVD player. However, I do believe DVD2ONE will beat the pants off of VCD's which is what I was authoring before. For me, the switch will most likely be a "why wouldn't I".
Open IFOEdit > Click Open > select your dir where your ripped dvd files are > select VIDEO_TS.ifo>open file Click on get VTS sectors.
May the force be with you. -
[quote="mikef07"]
Originally Posted by GreyDeath -
Life is good!!!!! Ripping with Decrypter, Transconding with DVD2ONE, burning with RNM DX all at once, all I have to say is if you want to wait around 8,9,10 + hrs go right ahead in the mean time i'll do 10 times the amount with decent quality!!!
[quote="DVC2"]For those that are still having having difficulties heres a short run through of the easiest way to do things.
Insert your dvd in your dvd-rom
start smartripper
select filemode
select the big button named backup
select a folder to save to (its important that the folder actually exist or smartripper will say its done in 2 sec and do nothing)
Smartripper finishes in 15-20 minuttes and you now have the entire dvd decrypted on harddrive (no you cannot use dvd2one directly from the encrypted dvd - you first have to decrypt and rip to harddrive)
start dvd2one - point to the video_ts folder of your ripped backup
select a folder where dvd2one saves the resulting files. (preferable on a secondary harddrive to speed up the writing)
select the videostream (thats the one with the longest playingtime - duh)
select the audiostreams which is identified in dvd2one with language and format
select the subtitle which is identified in dvd2one with language
hit start and in 15-20 minuttes your done
Now how difficult can it be
Ok, now just another Question for you ( from me a brain dead numbskull)
When you say just pick file mode then back up, are you saying we have to check every box in file mode? Because other wise even if you click on the File button, it still only has the VOB's checked to rip? ( SO what extra things do we have to rip?)
i am ripping my dvd again at the moment, but i want to know if i have to check all the boxes and ripp again?
Thanks, a little more specific than you last post ( about this area) would be great. -
your query is interesting, why not just check all,
then when dvd2one asks you what to do, you'll
have a choice...just a thought -
mikef,
A 120" projector is not a TV? Come on. That is an asinine statement.
What does TV do? It displays a picture.
A projector gives you 1024x768 resolution. Far sharper than a TV. Name something a TV can do that my projector cant. -
IvIark,
No matter how long you're sat in front of your PC, it still takes several hours for CCE to run through it's process.
As for the results being outstanding, well you're just obviously a "selective perfectionist".
I did Blackadder with DVD2One the other day and could see the results were diminished quality so decided to run it through CCE. Guess what ... still diminished quality albeit better than the original DVD2One results.
So my question to you is: Why are you prepared to put up with drop in quality with CCE rather than put onto 2 $0.80 disks especially considering that you won't have to lift your arse up from the comfy seats of your home cinema? Is $0.80 OK but no way $1.60? That hardly fits in with the impression of yourself you've been trying to put forward.
1) I've got a changer, so I dont' have to get off my arse to change disks.
2) I already split some movies to 2 DVDs if I want to retain 100% quality. This costs $1.60, which is no big deal.
3) I have a method to encode a move for 1 DVDR with CCE that gives excellent quality. Since it only takes seconds of my time to set it up, it's nice to get the movie on 1 DVDR when you would be hard pressed to tell the difference even on high end equipment. I can't say the same about DVD2ONE (see the doom9 forums also.)
You've done nothing but bash DVD2One
I've encoded many DVDs so far using CCE, and the quality is great. I already own it, and it takes very little time to use, so I see no point in switchign to a different product which I've been disappointed with the results (and not the only one, see the doom forums.)
Jason, I'm sorry but I make it a policy never to read the profile of people that are inanely boring. -
Originally Posted by musher70
Thanks again -
Did a test on a multi episode dvd using dvd2one. The episodes are 7 x 4:3 PAL full screen approx 28 mins each, total time 3hrs 20mins. Ripped the vobs (leaving out the 1st 8mb vob) to hdd, stripped out the video & audio streams using vobedit 0.6. Authored to titleset with Ifoedit 0.95 (no chapter points yet). Ran titleset folder through dvd2one to transcode down to 4.36GB, burned with Nero onto dvdrw. Disc played ok, some minor 'pulsing' (once per sec.) evident in darker background scenes. Overall I'm impressed with results viewed on a 26" (68 cm) TV.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
Your professionally calibrated TV?? HAHAHAH! What a joke! Whoever sold you that is laughing all the way to the bank. I can calibrate my own TV I think your DVD2One problems are user errors. I will put it in simple terms for you. What does a projector do? It displays a picture on a screen. What does a TV do? It displays a picture on a screen. Are you too stupid to realize this?? I think you are. Your HDTV gives how many lines of resolution horizontally? It gives 1080 at the most but since you are using a DVD it gives 720. My projector gives 1024 lines of resolution. So a 720 LOR dvd would be the same as your HDTV. Your logic, as usual, is flawed at best. Why don't you think before you write and stop making an ass out of yourself. If you want to troll this board, go away, none of us want you here.
I have had the full version of dvd2one for a few days now,and overall i am happy with it,i've done about 5 films with it,first was pearl harbour 3hr film,which it done in 20 mins,finished film was pretty good quality.Only one film seemed nearer to video cd quality than dvd quality.I used to spend up to 18 hours in a few cases with tmpgenc using high quality settings for long films,i always used tmpgenc for the last few months but will stick with dvd2one now.
mikef07 said:
Your HDTV gives how many lines of resolution horizontally? It gives 1080 at the most but since you are using a DVD it gives 720...
Antonio S.
P.D. mikef07, don't loose your time with this BLABLABLA guy ... -
I just finished ripping all the files, then ran DVD2one and have one new folder with all the files i encoded with DVD2one, so all the video and audio plus the subtitles, now do i make this folder called video)ts & then just make a blank folder and name it Audio _ts?
i m not sure wha to do once DVD2one has encoded the new files? DO i some how now need to take this folder with all these files ino Spruce UP or
can i some how just burn this new folder off after i rename it to VIDEO_TS & make the other folder with nothin in it AUDIO_TS in Record NOW 4.5?
Thanks in advance for help.
Does it have any sort of Menu or just straight Movie playing from beginning? -
I must say good proggy. I used it on Murder by#'s, Colleteral damage, and Run tell dat, with great success. Pic looks real good on my projected screen of 100", yes I do have a enfocus proxima LX540 in case any 1 was wondering. by the way 4 all of u that think record max is so great think again. I've had record max platinum 4.50 crashed my pc and cost me many coasters. I have Nero 5.10 and it's flawless everytime. For more info on record max problems check out www.cnet.com and read for yourself about record max blues.
Originally Posted by aaron10
Originally Posted by JasonK
I have so much fun showing everyone what a dumb ass u are. So what u are saying is a Projection is not a TV or sold as a HDTV well then lets just do a little looking, Sony what , what is this I see, A sony KP-65WV600 HDTV projection TV, well maybe sony does not know they can not call it a tv, shit we better let them know, Oh maybe it is a projection TV that is not a projector, Well you are still wrong ass, if u ever took apart a projection tv u will see a projector mounted in it going to a mirror that is displayed on the screen, Just like to Barco Projector That I use to test, and do not even think about saying anything about your high end equipment, The Barco's go for around $65,000. You do have internet, maybe u should stop looking at profiles and do a little research. Oh my a JVC AV-48P30 is also a HDTV better let them know false advertisment, But just incase u want a projection LCD TV a sony KF-60XBR800. Well have fun making another statement that makes an ass of yourself. And since u got a HDTV that had to be pro. calibrated, I think this whole forum has some swamp land for u.
Time to quit Jason, time to stop hammering the same same point.
I don't know where you are in the world (and I can't be bothered checking) but we have a saying in England...
..."when you're in a hole - stop digging'.
Let it go man, you clearly have a worthwhile overall contribution to make to this forum, but you're beginning to sound obsessive.
Take that as you will man
Originally Posted by jopereira
I'm not sure I understand this, as if you have to encode using cce then you have to use something like Maestro to convert the m2v and ac3 to vob's, right?
How is that faster?
Will
Wish I had $2k to spend on CCEtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
