I have disks I have backed up which are playable.
I then copy the files from one of these disks, to my hard drive to make a further back up and rewrite the files to another disk.
The new disk with the same files will not play - the DVD player says no disk.....what is wrong with them?
I have a Pioneer A04 writer with latest firmware 1.40, using bulkpaq purple Gen 3 media.
perhaps there is nothing wrong with yout writer, I had a similar problem and my HDD had bad sectors.
Run scandisk and defrag your HDD just to eliminate the possibility. -
Originally Posted by smytho
, if you own the DVD then you can copy it
If its a VCD, then a simple disk to disk copy is all that is needed. What is it ?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
