i wanna find a brand of cdr that works with my TOMPSON DTH4000 dvdplayer.....
i have tried various brands of cdr and i cant get any to work ...
It could be possible the unit actually has poor support for ANY CD-R?
I know nothing specifically about it, but I do know you have to shop around for a unit that does all things with all media...
<font size=-1>[ This Message was edited by: homerpez on 2001-09-02 18:03:54 ]</font> -
I had a toshiba (can't remember the model) and it wouldn't play any brand cd-r. But it would play cd-rw perfectly regardless of brand.
So, you may want to try cd-rw. And if it works you can pick them up in bulk for cheap. They'll never be as cheap as cd-r but if they work it's worth it. -
i would try to get some help from the players website. send them an e-mail for support. they can tell you more about your player than i can.
Can't find converter for mkv files that works...
By Syyner in forum Video ConversionReplies: 1Last Post: 16th Sep 2011, 15:21 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
What brand / pn works best with Magnavox ZV420MW8?
By Legendsk in forum MediaReplies: 0Last Post: 26th Sep 2010, 20:28 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Best CDR brand for longevity and where to buy
By headless chicken in forum MediaReplies: 7Last Post: 21st Jun 2007, 11:26
