I have an authored DVD on an ".img"-file and I would like to use SpruceUp to add chapters. Is the best way to demux all the vob-files and then add them in spruce? It seems like you can't just add the vob's in Spruce. Is there maybe another authoring-toll that can do this?
What happens when there are several vob's? Will Spruce look at them as several movies?
Sweet.
I think the best way to do this is use vobedit to demux the video and audio and then use spruceup. vobedit will take the video from all the vobs and make it 1 video and 1 audio, that is if you only have 1 audio track in the vobs. i think this would be the easiest. hope it helps.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 05:06 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
