I am starting this post to allow people to discuss using KVCD templates to create longer (S)VCD files.
KVCD is a non-standard (S)VCD templates (or X(S)VCD) which claim to (and do), allow much longer video on standard CDR format.
Firstly the templates are available here:
http://www.kvcd.net/dvd-models.html
They can loaded into Tmpgenc. The setup is onlined in the guide, here:
http://www.kvcd.net/guides/kguide/kvcdguide.htm
The setup is complicated, but main way of controlling file size (and quality) is the CQ setting. The lower the setting the longer the file, and the lower the quality. All this is in the guide.
The main consideration is the resolution, if you want to cram over 2 hours onto one 700Mb disk, then use a lower resolution template.
I used KVCDx3_NTSCFilm_352x480, with a quality setting of 46 you can achieve a 730Mb, 2 hour film. The quality is acceptable, about as good as VCD using Mpeg1. If you increase the resolution, and/or bitrate the quality is excellent.
I use the Mpeg2 templates, because Mpeg2 is better than Mpeg1 obviously.
I had to include VCD headers in the file in order to play them on my stand alone player, if you do this use the Mpeg1(automatic) setting in Tmpgenc, as this keeps the file size down.
If these play on your DVD player, then forget standard (S)VCD forever!!
Bax
Nah, forget DVD player.. encode at whatever resolution & bitrate you want, and play them on a PC!If these play on your DVD player, then forget standard (S)VCD forever!!
Hi Bax,Originally Posted by bax2097
Here's something you can use as a framework. Take a look at the sample posted in the following link, made with KVCDx3, and the posted script. It's from the movie "Attack of the Clones", and that's how the complete movie (142 minutes
) looks like on two CDs: http://www.kvcd.net/forum/viewtopic.php?t=2533
You can use that script as a starting point for all your encoding needs
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Hi Kwag,
How do I use the script you mentioned?? Where do I put it?? I think I get what you have done.
I this in the KVCD template somewhere??
Bax -
Hi Bax,
Read about avisynth here: www.avisynth.org
http://www.kvcd.net
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 08:01
