I am using Vdub to enter subs to a divx and the Vdub crash after a while probably a bad divx, i have tried DivxFix and even Vdub to fix it but still i have problems...(i have try on other divx-the same part- from difrent locations)
any other solution?
Try to load the DivX into Virtualdub. If you can, select Direct stream copy, and save with a new name. If you cannot even load into Virtualdub, then I don't think there is much you can do.
Then it is possibly connected with the way you are adding subs, rather than anything to do with the DivX itself. However, without more details of the process you are using, it is impossible to say.
Originally Posted by banjazzer
VirtualDub does seem to have alot less trouble with them though : )
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
Fixing [D] Frames?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 9th May 2010, 11:03 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Problem Fixing corrupted frames
By Blå_Mocka in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2007, 08:44 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 07:11
