i am trying to capture in virtualdub, and i have followed the guide on this site http://www.vcdhelp.com/forum/userguides/89899.php . i captured a 1 1/2 video with only 3 frames dropped, and when i go to play back the file it is only half the size it was meant to be (in gb's) and it says file type is unsupported. when i try to open the file in virtualdub it says that the format is unsupported. i have tried various other programs and cannot seem to get the right mix.
virtualvcr - same problem as virtualdub
iuvcr - audio/video sync problems, tried what is said in these forums, but i still get the same problem
avi_io - just crashes at start of record
card - leadtek winfast 2000 xp
drivers - ones from btwincap
compression - tried both huffy and mjpeg
os - windows 2000
cpu - duron 1ghz
mobo - kt133a kt7 limited edition msi
video card - msi geforce 2 mx400 64mb
sound card - soundblaster vibra 128
ram - 512mb
hard drive - 40gb NTSF
can someone please help me be able to capture.
btw virtualdub works for small captures, but doesn't for these large ones.
Results 1 to 1 of 1
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 05:21 -
Virtualdub help
By Rogert in forum Newbie / General discussionsReplies: 10Last Post: 2nd Sep 2009, 15:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
re: virtualDub
By merlie in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 14:50
