does this thing disable or work around macrovision? if so, is there a special button or does it do it automatically? also does anybody know if the DataVideo DAC-100 does the same thing?
Laserdiscs are cool, but laserdiscs on DVD-Rs are cooler.
Hold down the input select button for a minute or two and it will disable the macrovision.
Actually I only hold it down for about 20 sec. and I think that may even be overkill. If you have a TV you can connect the svideo out on the back to, you hold down the button for a few seconds, and color bar appears on the TV screen, you continue to hold down the button until the color goes away again.
I wish some one with a tv hooked up to this thing would actually time the process, so I could know EXACTLY how long I have to hold that damned button down for sure
I hooked it up to my TV.
It's 4 seconds till the color bars appear and at 15 seconds it disappears. So at 15 seconds the Macrovision will be disabled.
Macrovision and Canopus ADVC 110
By nikgelfi in forum Capturing and VCRReplies: 2Last Post: 13th Apr 2011, 17:09 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-100 - capturing with macrovision disabled.
By MikeMGMVE in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2009, 20:48 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
