Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Member ralfbeckers's Avatar
    Jun 2001
    Western Europe
    Hi,
    can anyone tell me what the Video-CD 1246 kbps template in the extra directory is for? Does it create a VCD with an additional 100 kbps data for video? How is that compatible with the "official" VCD 2.0 standard and will it play on all VCD capable machines?
    It makes sense to me to get as much bandwidth for MPEG-1 video as possible but where do the extra 100 kbps come from?
    Regards
    Ralf
    Feb 2001
    Berlin, Germany
    There is the audio set to 128 kbps instead of 224. So it is a XVCD.
  3. Member ralfbeckers's Avatar
    Jun 2001
    Western Europe
    I see. Won't that make VCDs sound even crappier than they already do? Have you tried it out?
    Is the trade off worth it?
    Ralf
    Feb 2001
    Berlin, Germany
    I use tooLAME for audio encoding. For me 128 is acceptable, unless it is a music video.
  5. ralfbeckers,
    VCDs sound crappy??
    At 224kbps, MPEG-1 Layer 2 audio has essentially CD quality sound. If your audio sounds crappy there is probably another reason for it...
    As Truman has stated, if you are using TMPGEnc (which has a poor audio encoder), you should use the tooLAME plug-in for audio encoding.
    Regards.
    Michael Tam
    w: Morsels of Evidence
