i for some reason had a problem with opening my AVS file or AVI file in CCE,It was saying my frame rate is not supported? if i look at both files , the AVS will say frame rate 20000/1000 is not supported, then if i try the AVI that DVD2AVi creates, it says -1052 x 56 is not a supported frame rate, it should be 23., 24, 25... etc...?
i don't know why this is? can anyone help me please?
"thingimajig" whre are you, you sound pretty experienced can you please help me again,
