when i attempt to make a dvd with ulead dvd workshop, it plays fine in my sony dru500a, but when i put it in my standalone pioneer dvd player it will not play audio. can any one help. ive tried capturing with the audio at 44.1 and 48. still no luck. ive authored dvds with sonic mydvd and ulead movie factory and they worked fine in the same dvd player
Did you use MPG or PCM audio. Some DVD players have problems playing MPG audio. PCM and AC3 (which DVDWS dosent support) may work better.
Have you tried the completed DVD in another DVD player?
Have you created more then 1 DVD and used another video project and are still not getting any audio to play?
i've been using DVDWS sense it came out (9 or 10 months ago) and never had a problem with audio.
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
