Hi,
I've been a minidisc fan for a long time and I really like the audio quality of sony atract compression codec. A few months ago I found Sony Atrac 3 codec for windows.
I been doing some testing and I think it works OK.
Any experiences out there regarding the use of Atrac 3 codec for AVI files creation?
Thanks.
Could be an OK idea, but it is limited in terms of compression efficiency-compared to other newer codecs. Most people here are trying to eak out every available quality per MB or bitrate. Also, not that many people have that codec so it would really only work well as a personal backup solution.
What I see that would be cool would be if you could do a straight digital Xfer via an SPDIF connection from MiniDisc to Computer. Then there would be no A-to-D and D-to-A loss of quality.
Do some experiments and let us know...
Scott -
If someone doesn't have the codec on their computer then they could not play your files. For personal use though it would probably be a good codec compared to some others.
Panasonic DMR-ES45VS, keep those discs a burnin'
Sony DSC-HX5 and AVCHD movies
By nitay in forum Video ConversionReplies: 1Last Post: 23rd Mar 2012, 11:41 -
Sony Vegas 9 can't play audio of my AVI file!
By darkdestiny in forum EditingReplies: 19Last Post: 27th Dec 2009, 03:42 -
Sony Blocks Movies from Xbox 360
By MOVIEGEEK in forum Latest Video NewsReplies: 7Last Post: 4th Dec 2008, 11:35 -
Divx (.avi) movies with 5 sec audio delay - can these be saved?
By Hank Kinsley in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2008, 23:20 -
Can i watch HD movies in Sony RDR-HX 720
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Nov 2008, 08:56
